Yes. The BLK and BLK/GRN go to the outlet. Tie the other two wires BLK/WHT and BLK/RED together and insulate them. In this manner you will have 240V capability and proper transformer phase on the input wiring.To tie them together, isolate them and then the BLK/GRN and BLK go to the socket?
HiHello omri617
Yes, but a 240V modification is not only this simple connections
Normally all MAC1900 were supplied with worldwide market power transformer
The connexion you are talking about are not complete
Is your problem to use original power transformer in 110V wired with 240V connexions ?
Last service manual is 039-044
What is your serial number ?
ThanksYes. The BLK and BLK/GRN go to the outlet. Tie the other two wires BLK/WHT and BLK/RED together and insulate them. In this manner you will have 240V capability and proper transformer phase on the input wiring.
He has a tone control. I bet he knows how to use it. I would also think that the Israelis are more advanced that most of continental Europe and are using the newer Optimod processor where the de-emphasis time constant plays no major role anymore.OK but what is your country ? Israel ?
The other important modification is of course the de-emphasis because you have a receiver
Yes israelOK but what is your country ? Israel ?
I can’t find 10% 8.2K ResistorsWhat do you think made someone (or McIntosh?) to remove this 8.2K 5W resistor?
It adds up to the mystery :
1. missing transforme
2. Missing filter caps
3. Missing rectifier diodes
