totem
Addicted Member
Let,s take another shot at this, with no monetary component. What I do know is the mc-300 puts out the same wpc regardless of output load. When these amps are bridged and running in mono 600 wpc, @ 8 ohms will this mono figure also be valid, ie one that can be used to run a 2 ohm or 4 ohm load as well? Most other brands when running bridged are not rated for much below an 8 ohm load.
