Greetings, I'm having problems with my MAC1900. The left channel is weaker than the right channel - that is, it sounds a bit lower in volume. The left channel also sounds a bit muted or lacking in presence as compared to the right channel, but perhaps this is a result of the lower volume. I swapped the preamp boards, and the problem did not move (i.e. stayed on the left channel). I put the preamp boards back to their original position and swapped the amp boards. The problem stayed the same (i.e. stayed on the left side). So to my way of thinking, the problem is not in any of the PCBs. It could be in the volume or balance controls or in the output transistors. I'd appreciate any suggestions before I dive into it further.
Thanks.
Thanks.
