Maggie 86-01 volume control question
JohnMac
Addicted Member
I did a modified version of Kegger's 86-01 mods. When I install a 100k volume control it goes from minimum to max within about 1/8th of the rotation of the pot. There is a 10k resistor from the 5 and 8 pins of the 6EU7 to the inputs and 1Megs to ground. I've also tried it with 270k to ground. Any ideas?
Thanks,
John
All the packaging said was stereo volume control. There are two rows of three terminals. I assume the top row is one channel and the bottom the other with the center terminal being ground. That's how the original control was wired. How can I tell what type it is?
Log taper pots have the letter "A" as a suffix, and linear pots "B".
az
