The 6sl7 used will clearly affect the sound output quality. Some distorted a bit , others will cary it to higher volume before clipping.
How will replacing the input resistor help? Will there be an audible difference?
I ask for knowledge. I will do this for sure.
Yes, measurements were taken with a preamp connected. I'll remove and check again.
I did some playing with it yesterday, some tube rolling. The 6sl7 used will clearly affect the sound output quality. Some distorted a bit , others will cary it to higher volume before clipping. Also, I used several different rectifiers in the unit. The PS tranny got slightly warm - just warm enough that you could tell it wasn't cold.
Aslo, on the od3's, they all act differently. Some would not even light up. Some would only illuminate the bottom section, others would burn really bright.:scratch2:
Hi Mark ,
Lowering the imput impeadance does have an effect , it make the amp quieter , but harder to drive and orverdrive .
Instead of going for higher B+ , you could lower the screen voltage with a devider net work after the shunt regulators .
Scuzzer, to set the bias for the 6sl7, I ned to change teh 8.2k resisor - correct?
I'll drop the input impeadance to about 2.2k.
Do you think 220k is right, that seems awfully high. Maybe 20k I would have thought.
470k is a fairly high grid resistor, you just may want to use something more conservative like say 200-270k there instead.
The input 6SL7 section is only biased at -0.17V according to your measurements so it would be quite easy for tube to tube variation to be huge. Once you get the bias to -1 to -1.5 volts the distortion should go away (spec is -1.6v). You could put an input capacitor on this amp to make sure that preamp offset voltage isn't screwing up your bias.
This is waht I was trying to refer to.
What pin on the schematic/waht resistor are we talking about here?
Mark
You've got some mislabeling here.
"The measurements were consistent from tube to tube, so I am only going to list the values of one of each.
TUBE pin schematic Measurement
6v6gt 2/7 heaters , 17.5 volts??? What
6v6gt 3 plate 295v , 286
6v6gt 4 screen 305 , 288
6v6gt 5 screen 0, .2 to .3v .............. (THIS IS THE GRID/INPUT)
6v6gt 8 cathode 18.5 , 17.5
5y3 4/6 290 , 315
6sl7 1 screen -.1 , 1 .................. (THIS IS THE GRID/INPUT)still working on this
6sl7 2 plate 95v , 78.6
6sl7 3 cathode 1.5v , 1.17
6sl7 4 screen 0 , 3.2mv .................. (THIS IS THE GRID/INPUT)
6sl7 5 plate(b) 140 , 123
6sl7 6 cathode(b) 1.7 , 1.92
6sl7 7/8 heaters , 17.5"
And any of the grids should have basically no voltage on them, I usually suspect
a bad or at least "leaky" coupling cap when they have a few volts on them there.
(anything under .5v here I'd call just a meter sense thing)
Now to get me new preamp.:sigh:
So waht is next - remeasure the voltages while using the 5u4's? See if that helps?
One thing I think migh be happening. When I turn up the volume, it is fine to a point, then it distorts very badly and the 0D3's flicker and can even go out. Almost like they are incapable of handling the current needed for the amp.
If they're going out that means they don't have the necessary 5ma going through them to keep them lit. When the amp is pushed hard the screens are at their maximum current draw and may be pulling enough to push the voltage down too low across the 2k resistor.
Measure the voltage before and after the 2k resistor and we should be able to tell if we need to change that resistor value.
