guitargrump
The capacitor I have circled is C19B...
The diagram shows C19A connects to ground...
C19A was removed from my 175-67 module... Why?
Is C19A the infamous death capacitor?
Shouldn't C19B be a safety Capacitor?
I think C19A is a death capacitor. I’ve only heard guitar guys talk about them. They are connected to the amp and kiss microphones, stereo listeners just touch the plastic knobs. Still looks like a danger, if it shorts.
It is “shocking” how much crazy info is out there on the internet (I just searched “death capacitors.”) People claiming that power supply capacitors have “thousands of volts” and maintain lethal charges “for years.” No guys, death caps are tiny caps that can short and energize the chassis.
They are there to filter out RF noise. I usually replace them with new X1Y2 ( I think that is the correct version) caps.
You can eliminate 99% of any potential shock hazzard from that cap by changing the line cord to a polarized one and running the neutral side of the line to the cap. Then it will only be the line ground to chassis if the cap fails by a short. But it would be better to have it go from the hot side to the neutral to detour the line noise and power spikes from lightning, etc..
ecc83's are = to 12ax7's. I think a 7025 is 1/2 of a 12ax7.
boogying to a pocket radio while a nice stereo setup sat silent in front of me. It be that way sometime.
It's the other 12ax7 equivalent tubes numbers I'm trying to find like for 12au7 ect...
