Hi everyone,
I have been lurking here for the past few days and have quickly been exposed to a wealth of knowledge and picked up on a few ideas about how i am going to go about this rebuild. Recently i found a 175-67 for a good price. It is supposed to be in working order but the power cord is in pretty rough shape so i am going to replace that before i do any type of powered testing. All the tubes are in place and the gentleman i purchased it from said he had tested them and they were not super strong but should be usable. They are all different brands but they are there. I plan to use this as my daily driver amp once completed. I have a couple speaker choices but it will probably be used mainly with my Elac Unifi B5 or Debut B6 (i liked both so kept the debut after i bought the unifi's). I have a couple of other choices but they are floor standing speakers that i would rather not move out of the living room. I would also like to add a headphone out at some point, more on that below.
So.... My plan is to replace all the wiring, caps, resistors and anything else that hasnt held up too well over the past 60 years or so. I am slightly skeptical of the output transformers because they dont look to be in the best condition. i am not measuring any shorts so i think they will be usable for rebuild and testing purposes. I will replace them with something better once i have it up and running. I have read something about ultra linear that seems interesting so i hope to look into that a little more and may go that route if it would be of benefit.
The 6v6 tubes are are all different brands so they will be replaced with a matched set of New Production TungSol's once i am satisfied i have everything in working order. Any suggestions for improvement or cautions while rebuilding the power stage would be appreciated. I try to approach everything with a mindset of cost vs reward so i am not really interested in the ultra rare, unicorn blood driven tubes out there that have tiny angels singing a chorus inside them. Honestly, i probably can afford them but probably couldnt tell the difference between them and the Tung Sol's so my mind is pretty much made up there. From what i have read on here, there arent really any bad 6v6's so that seems to be pretty much settled for now.
The Power transformer looks to be in really good condition along with the choke so i feel like i am good there for the time being. In the future i would like to buy some quality transformers that arent eye sores but for the now i just want something that is safe and will function as expected.
My questions come in on the 12AX7's. I have a friend that has a pair of 5751's that he bought years ago that he says he has never used. If he did use them it was a junk socket because the pins arent scratched at all. This amp will only be fed line level signals so is it necessary to have the extra gain of the 12AX7 or would i be OK using the 5751's? I have plans of getting my record players back out at some point but i have pre-amps for them. In the end i dont see a situation where i will ever be feeding this amp weak signals that dont first go through a preamp or mix panel. I can get the 5751's at a very good neighbor discounted price right now but dont want to waste the funds if they wont work. He is downsizing his collection so if he is letting me have first pick on everything before he puts a lot of it on ebay and sells it.
I would also like to add a headphone tap to this amp at some point in time. I plan on buying some HE-6's in the hopefully near future but for now i mainly use my trusty HD650's. I have been in love with the HE-6 since i heard them at few years ago so now that i am in a position where i can afford them without eating ramen for 3 months, why not. I dont want to end up damaging the headphones or my speakers if i do this so i have been reading up on some different types of attenuators and impedance matching in order to try to get a grasp on how to do this safely yet get good results. Any and all suggestions here will be appreciated. I have a few ideas of how to go about it but right now they are just ideas. This is not set in stone but i would like to be able to continue using this amp even after the misses goes to bed without fear of being banished to the yard. This may be a subject for an entirely different thread once i get closer to implementing it.
Anyways, this will be my first full tube amp rebuild so i am really looking forward to it. I plan to implement all of the standard stuff too, power switch, fuse, and power indicator in order to make it a little safer to operate. Over the years I have replace components, fixed friends guitar amps and all of that stuff but never took the time to build or rebuild an amp. The way i look at it is for the 60 bucks i will have in the chassis, transformers and mismatched tubes, it is worth going a little further and hopefully have something that sounds halfway decent in the end. I dont plan on throwing a whole lot of money at it but i wont be skimping on junk components or cutting corners either. If i am going to rebuild it, which i plan to, i want to do it correctly in order to have something to use until i get the inkling to upgrade again. Plus it will keep me out of trouble!
I hope to take some pictures as i go and will share them here if there is any interest.
