I have a pair of Hammond 1620a"s on the way. The amp is a 185 with the 7025 removed, all caps and resistors replaced and coupling caps upped to 0.1 and 0.01. Sounds great, I just want to give it 8ohm taps and some more range. I sketched out how I think it should be wired, but I would appreciate any feedback before I go ahead and install them. In the schematic I used the UL taps, but I will probably use them without at first, then compare later.
Mainly I want to make sure the feedback loops are correct. Since they were wired to 4ohm taps, I just copy that?
