Member GordonW uses 6L6GC's in Magnavox amps he has supped up. Maybe send him a PM. He would give good tips on how to rebuild the power supplies and such.
Not with these output transformers. Mine use the heavier outputs, found in the AMP101/AMP128/AMP132/AMP142/AMP150/AMP179 amps (the PPP 6V6), which are fine with a pair of 6L6s (one pair of 6L6s can provide about the same power output as a quad of 6V6s).
The AMP175/AMP185/AMP164/AMP169 outputs can actually be saturated in the bass, with an optimized single pair of 6V6s. There's no real reason to use 6L6s- these transformers will just saturate at an even higher frequency, as you force more power out of them...
Regards,
Gordon.
