fiddlerman
Hi everyone,
I'm about to acquire a console-pulled Magnavox 185. It worked last time it was hooked up, which was several years ago. The buyer is recommending that I replace all the capacitors, which I'm planning on doing.
But I'm at a crossroads. The 185 was phono-only amp attached to a turntable with a ceramic cartridge. Is it safe to assume the two RCA ins are above line-level but not up to the level that would accomodate a magnetic cartridge?
If so, is it absolutely necessary to remove this phono pre circuit? Doesn't keeping it in just make the amp "louder" than line level?
Silly newbie question, I confess that my knowledge of electronics is next to nothing.
I've read a lot about people removing the phono circuit to convert the 185 into a 175. What I'm asking is whether this is actually necessary. Is there a good reason for this? Would keeping the phono circuit intact raise the noise floor of the amp?
Has anyone here hooked up a line-level device, such as a preamp, through an 185 phono circuit as it stands?
I'm planning to use an external pre-amp selector to run this amp.
Thanks in advance for your answers.
