So just for giggles I decided to take the voltmeter to my Magnavox 8802 amp that I have lying around after reading about the bias levels that Magnavox shipped them out the door with. I was curious how mine would measure and this is what I found on the 6V6:
286v plate
285v screen
17.8v cathode
180 ohm resistor
So if my math is right I figure that each tube had just over 23ma of plate current running through it (when I removed the stock 180 ohm resistor I found that it actually measured 199 ohms in my unit which was causing the tubes to bias even cooler than that) with only about 6w of dissipation. So in the interest of getting this amp's blood pumping a little I replaced the 180 ohm resistor with a 120 ohm after which I got these numbers:
268v plate
267v screen
15.6v cathode
120 ohm resistor
6.57v heaters
Again, excluding faulty math, I get about 31ma per tube and right about 8w plate dissipation after changing the resistor. My question is should I stop there or can I squeeze just a little more out of this amp? I have a 100 ohm resistor that I could try as a next step. I know that the 6CA4 rectifier is only rated to handle 150ma of current so getting to about 35ma on each of the 4 tubes wouldn't leave much for the rest of the components. Also, should I care that the screen voltage is pretty much equal to the plate voltage although the schematic shows the screens riding 10v lower than the plates?
286v plate
285v screen
17.8v cathode
180 ohm resistor
268v plate
267v screen
15.6v cathode
120 ohm resistor
6.57v heaters
