I recently acquired a Magnavox 9302, and I'm in the process of rebuilding it. I've stripped the chassis completely, and I'm nearly done doing the mechanical work on the chassis... soldered over the extra holes, body filler, all the aesthetic stuff.
I'm having some trouble with the schematic, though. Everything I've found on here is very low-resolution, and most of the schematics I see have some modifications. I've put together my own schematic based on the original with a few major differences:
I've attached the two schematics I'm using for reference as well as my own schematics (9302-Power and 9302-Audio). The volume control is missing from my schematic, but it should otherwise be complete.
(If it makes any difference, this will be fed from a Little Bear T11 phono preamp swapped with 12AX7 tubes; this has a volume control and a very hot output at high volume. For now, at least, it will be powering a set of Polk Ti500 speakers @ 8ohms with a sensitivity of 91dB).
- Both of the output transformers are Edcor CDKPP-MS-25-8K with a 23% screen tap.
- The power transformer is an Edcor XPWR008.
- R112 / R109 - Since I don't know the difference between each model of the 93-series, I'm not sure what values to use for reference. Additionally, since R112 is the feedback resistor from the output stage, does it change things since I'm wiring it for ultra-linear mode? I have read than in UL mode, feedback is often not necessary. Is there any truth to this?
- R117 - I'm using a balance pot, and one of the schematics I'm referencing has a 300-ohm resistor from either leg of the pot to ground; this isn't part of the original schematic. What's the purpose of this, and do I need it?
- Pre-amp Tubes - I'm swapping the 6EU7s for 12AX7s. Other than the different pinout and heater wiring, should I be aware of anything?
- Output Transformers - I'm willing to trade power for frequency response, so I want to build this in UL mode. Other than wiring the screens into the output transformer screen tap instead of +300V, are there any recommended modifications?
