Magnavox Astro Sonic pot trouble
6nylonvinyl
Hey all,
It's my first post. Hoping somebody might point me in the right direction. Basically I've a volume pot that's gone bad on my Magnavox Astro Sonic (chassis # R23104 DA). And, I need a replacement.
The conductive material has worn off of the left channel's wiper. As a result I get very little volume until it's turned up all the way up. It's a dual gang 100k audio taper with uh?.... 10-pins!?! Why? I don't get it... And, I can't find anything like this on the net. I've searched the usual places. No dice.
Anyone know: 1) Where parts be for this dinosaur and 2) What is the deal with the four extra pins on the pot? 3) Can I use a normal six pin pot (given all other specs the same:IMG_0031.jpg IMG_0029.jpg 100k, audio taper etc.)?
Schematic on order, btw. Here's a few pics>>
Thanks,
Todd
Since he is new, not sure he knows that it would be good to follow up and not leave us hanging so I am posting the final results. This is 6nylonvinyl taken from our private conversations:
Pot came early! Received it yesterday. Thank you so much! Installed it and it works! Finally both channels are functioning... Here's some pics....
To answer the OP’s question regarding the extra pins, the upper connections on each section (4 total) are probably for a loudness contour eq circuit. As the volume level is increased they want to limit the bass frequency boost. Good on ya century tek for helping a brother out!
