Magnavox ID?
Stevel
Member
I may take a look at this Magnavox console and auxiliary speaker that is for sale locally. It looks very similar to the Magnavox 295HM (with AMP150) I owned, however, the tuner dial is a little different (band numbers are not lined up). The owner does not know the model number. I was hoping the separate speaker was amplified, but I do not think so, as there is only a speaker wire protruding. Any ideas?
Check out this AK thread
Stevel, Like later car models, sometimes the only new features were cosmetic (redesigned Dashboard etc!). Your Maggie appears to be a 295 and The console is without a stereo Channel, So my guess is that the satellite cabinet itself might be powered. Go to this AudioKarma forum thread. (http://audiokarma.org/forums/showthread.php?t=192601) hopefully this will steer you towards the answers that you seek.
Thank you for the info and link, Zandru. I own a few of those Maggies posted on that AK link with the great, vintage advertisements. I hope your are correct regarding the satellite cabinet being powered. I can not get much info from the seller, but asked if there was a power cord out the back, and he said no, just a speaker wire. I will check it out tonight (if it is still available).
I've got that console : )
the amp will be stereo, and *99% sure* bi-amped on a single chassis. . . p/p 6v6 for the woofers, SE 6v6 for the tweeters . . .
VERY COOL ! one of the very early stereo maggies . . . .
Good call, Markus. Just got home with the unit. It is a 1SR295 H 1. Sure enough, Magnavox AMP182, BI-amp. Has PP 6V6 outputs for 15" woofers, and SE 6V6 outputs for the horns. The speaker is still in my car, so I have not checked the condition.
My 295HM must have been a year or two older. It had a mono AMP150, so I am happy about this new acquisition. The cabinet and top glass panels are in good shape. I look forward to re-capping the amp and tuner, servicing the changer, and giving it a listen-to!
Steve
