Magnavox Model # 2P3463 End Table Stereo Console
rolf logan
Hello,
I just picked up the captioned record player/radio for $50. I plan on restoring it. Radio works great, speakers do as well. So, I only need to get the turntable operational.
When I go to Turntable Needles, they don't have the model # listed, so I will pull the cartridge to get the numbers and try to find the needle that way.
This is what's going on with the record player. You can set a record on the spindle, suspended above the turntable. Turn the record player on and It goes through the motions, turn it on, it drops the record and then does exactly what it's supposed to do, except it goes real slooowww. Like super slow, all the right moves, just slow.
So here are my questions - Any clue as to the problem with the turntable? Also, on the front of the display, there is a number - 151352 3. Any idea as to what this number gives reference to?
Photos attachedIMG_7640.JPG IMG_7638.jpg IMG_7639.JPG IMG_7640.JPG IMG_7638.jpg IMG_7639.JPG IMG_7641.JPG IMG_7642.JPG
Also, if anyone has a manual or wiring drawing, it would be much appreciated.
The turntable probably needs a good cleaning and lubrication. It may also need a new idler wheel which you can probably get from The Voice of Music.
