Magnavox Tube Console Preamp Needed
Actually- that's 300v B+. The plate voltage at the tube plate pin, is only about 60 to 120v or so (depending on tube and cathode resistor).
If you are talking B+... if you can get B+ voltage up to about 175v, it would work well as-is. You might want to increase the cathode resistor to 910 ohms- that should work a little better in terms of the distortion spectrum.
And, the 6CG7 works better than the 12AU7, at that low voltage, too.
Regards,
Gordon.
Regards,
Gordon.
Sounds good Gordon, I have not used the 6CG7 tube before but have read good things. Ill have to give it a try. Thank you.
Single 12AU7 or 6CG7 (prefer 6CG7) for stereo channels, 0.1uf input caps, 470K grid ground resistors and 1K grid stoppers, 820 ohm 1/2w cathode resistors, 22K 2w plate resistors, .22uf 630v coupling caps. Run it on between 275-320v B+. Feed that into a 100K stereo pot, then into the existing first tube in the Magnavox amp, through a 1K grid stopper (change the existing stopper resistor, if there is one, to a 1K- or add a 1K if there isn't an existing grid stopper).
I've lost count of how many times I've done that- and it ALWAYS sounded great.
Regards,
Gordon.
How much gain? Why not 6SN7?
I recently sold a Maggie amp and preamp combo (console pull) to @rossm, and I believe the preamp had a schematic attached. If he still has it, maybe he'll take a picture of it to share.
6SN7 is a drop-in sub for the 6CG7. Exactly the same parameters. The circuit requires no differences. Should sound pretty much exactly the same, with the obvious caveat of typical tube-rolling type differences (different brands and such).
BTW: Total voltage gain for the circuit I spec'd is about 12.
Regards,
Gordon.
I've used my Magnavox with Audible Illusions Modulus 3, Pilot SP216a and 210 and Superphon Revelation dual mono preamps.
I prefer the sound using active preamps.
Most of mine run passive thru a Noble 10k stepper controller. Gordon's circuit shows a near perfect tube line stage, imo, if I was to use one. Next best is a simple fet setup, either if the gain is needed. Most preamps are redundant signal path obstacle courses and sound like it.
Ymmv.
Thanx! Same as my CJ Motif pre, I think.
Iirc, 6CG7 is metal can, 6SN7 glass only.
Other way around. The 6CG7 is a 9-pin glass tube (Noval, like the 12AX7 and such). The 6SN7 is octal base (both metal and glass bulb versions).
The 6CG7 would be easier to add to a Magnavox amp- most have an extra socket hole that would have been for a 7025 for a phono preamp- that's the same socket type and size as the 6CG7. But, if you're building a stand-alone preamp, then either would be equally easy.
I have it confused with an an octal alternate for the 6SL7GT then. I have a couple Calrad phono pre, one that uses a 12AX7 and the other the metal octal tube I apparently misremembered. The 12AU7 would be the alternative then.
A Baldwin carcass now minus opts I have here has that unused socket hole. I considered changing it from paraphase to Mullard, but an additional stage is a possibility, tho it's probable I won't get around to either. It was to be my 6L6 amp.
Maybe you were thinking of the 6SC7? It's similar to the 6SL7, except for having a common cathode for the two sections.
Regards,
Gordon.
Nice! I play guitar too, been thinking of changing resistors and caps in my fender blues deluxe reissue. For solid state I have a Marantz 2230 that sounds amazing but need to source new transistors before I recap it. I prefer working on tube stuff but this is a ss worth fixing up, warmest ss I've heard. I also have a Pioneer sx 850 that I'm thinking of selling. I don't have a huge budget currently but am trying to get more into the tube stuff. I haven't been able to hear many different tubes yet but am hoping to go to the rocky mountain audio fest next year.
I am using the Marantz 2230's preamp outs with my 9303 Maggie and I gotta say it sounds SO good. Holographic, detailed, dimensional. I love the 2230 power amp, but it seems a little less three-dimensional than the Maggie, which I have outfitted with extremely heavy Edcor transformers.
