Magnepan MMGC help
8diagrams
Hi - I just purchased a Magnepan MMGC speaker (used) and it arrived with the wiring disconnected from the inside of the speaker. It is still connected to the part that you connect the speaker wire to, so I know which wire is the positive and which is the negative. I need to know which "plug" on the left inside of the speakers is positive and which is negative. Any help would be appreiciated. Thanks :)
The wires connected to the plugs are color coded on mine. Unscrew the panel holding the plugs and look.
Red and black.
Hope this helps.
Eric
