In the AMP 175 series of amps, they have the common speaker connections towards the rear whether molex or lugs, and the left speaker terminal screws next to the capacitor on the chassis. My AMP 175-67 actually has the terminal lugs labeled as C, 1, and 2. Plus, it also has the screw terminal for speaker #2 which is used for the left channel speaker in separate cabinet models.
Josh's amp 175-67 uses the molex connectors whereas mine uses the the lugs or spades. I don't believe that there is a wire attached to the left speaker screws. As said before, those screw terminals are used when the 175 amp is used in those separate consoles.
Josh, are both speakers connected? One black wire and one green wire on both right and left speakers? Any black wires are all ground wires and are connected to the chassis as ground. This is why you might see one black wire someplace and no black wire in other places you think they should be.
Wires won't come disconnected by themselves unless it was jarred real hard or dropped, or the previous owner touched something, But all in all, your best bet would be to have someone else have a look at it because it's hard to help over the internet, but I could have that diagnosed in 5 minutes. I do these in my sleep!
Its either a component in in the amp or the receiver and its tough to try to nail it down especially if you are a novice at these things. What state are you in? Maybe someone here is close to you and can come to help you out.
If you're getting scratching sounds from the bad channel, that is a good sign (at least to me anyway) that its nothing major. I don't think the speakers are blown, but you can always take a 1 1/2 volt battery and touch it both speakers just to make sure none are blown. Touch the battery to the big speakers (woofers) only.
There is a 12AX7 (or 6EU7) tube up in the radio receiver. This could also be a contribution to your problems. If you can and real carefully when it is on, rock the tube gently in its socket.
Also, and this is rare but has happened, one side of the inside of the 12AX7/6EU7 tube could be burned out. In other words, when the amp is powered up, if you look at the 12AX7 tubes in the amp itself, you will see what looks like two sticks inside the tubes that are glowing. These are called the tube's heaters. Sometimes one of those burns out but the other half is still lit. Just something to check.
I know you are trying to good, and you are doing good for what you know, but it does get a little bit frustrating if someone is not there in person to help. By the time we get done here, You will have learned a whole bunch!
