Day 1 newb here. I just set up an old Technics amp and connected some Sony speakers and a subwoofer to the 2 main and 2 remote speaker ports. I understand the intended use for these ports are for different rooms, and you wouldn't normally use both together, but I want to use them both. The issue is when I play from main or remote, the sub works fine. But when I try to play both at the same time, the sub stops working and only the speakers have sound. (Speakers and sub are all rated at 6 ohm impedance)
I've looked at some threads here and it seems like there is conflicting info. Some say they should work at the same time and some say the only way for this to work is to connect them in series (which I do not know how to do) or get another amp. Can someone explain why this wouldn't work and if there is a solution?
