Hi, N00B here.
My post below is longer than I planned, so here's a "TL;DR" synopsis of it:
1) What should I replace my Stanton 500 mk1 stylus with for better sound quality (£40 or under)?
2) My Soundlab DLP1R is running slow despite a new drive belt. Is it time to try to adjust the pots on the deck near the slider? Anybody have experience of this? Do I need some 'spectacles' style mini scredrivers?
3) Will changing my Preamp from a BTECH BT26 to say, a Pro-Ject Phono box MM or Pro Ject Phono Box E make much difference to sound?
4) I occasionally get that "dit dit dit" mobile phone sound interfering when the turntable is in use. Can it be prevented?
The longer version:
I am not an audiophile, so I'm coming to you guys for your knowledge . I tend to spend my money on music (CDs, gigs) rather than on equipment. Please don't hate me!
I've had a Soundlab DLP1R turntable since 1999. Nothing fancy but hey, it spins the records.
It came with a Stanton 500 Mk1 cartridge and needle, and I also bought a BTECH BT26 Preamp from Richer Sounds in London. At that time, the BTECH was the only preamp that those guys stocked, and I think they continued to stock it for about 20 years until it was discontinued (in 2019?). So Richer Sounds must have thought it was reasonable. I've never changed the needle because I've used the turntable lightly. I'm more of a CD guy. I have thousands of CDs but only a couple of hundred records - mostly 12" singles.
Another reason why my TT has been used lightly is because, from day one I've never been happy with the sound. I've always noticed a drop in sound quality when switching from my humble Panasonic Stereo (with "MASH" 5-disc CD Player, ha!) to the record player.
I know vinyl is different from CDs, but my record deck never seemed to sound as good as the record store decks in HMV which also had Stanton cartridges on them. I used to regularly listen to dance music 12's on the in-store decks in HMV and other shops (e.g. Phonica in Soho). Could it be because they had Stanton 500 MK2 instead of Mk1?
I was also perhaps spoiled before leaving home in Dublin (1995). My dad had a Technics SL7 parked atop his hi fi separates and it always sounded fantastic combined with his Technics SU V7 Amp.
Recently I decided to replace my Soundlab's drive belt (for a fiver), and the local HiFi store guy chatted with me on the phone about my record deck and said: "if you want better sound quality, go for an Ortofon for about £50".
Well the concord style Ortofon cartridge I looked at online was more like £75 - which I didn't want to spend.
So I decided to look at better stylus options without changing cartridge. I plumped for an "LP GEAR Stanton N500S Universal 500 Series Elliptical Upgrade Stylus" as listed on Amazon for £24.99 here (that £24.99 listing may be about to be removed though, see next paragraph!). I don't do scratching or DJ-ing, so eliptical seemed like a good idea for better sound.
The stylus arrived today. BUT the seller, Computerstar have sent me the wrong one. They've sent me a "KYOWA (Blue dot) ELLIPTICAL DJ STYLUS" as listed on their own website here. They have acknowledged the mistake to me today (they linked their product to the wrong Amazon ASIN number/listing) and confirmed that this cheaper stylus is what they *actually* sent. It's almost half the price! Well, it is nonetheless an eliptical stylus so it's probably better than the one that came on my turntable, right?. Well I've had a listen now and honestly I don't thnk it sounds any better than the old one (which I presume is conical).
So...I don't think I want to keep this Kyowa stylus (is it a good brand?). It seems like I'm not going to be able to get an LP GEAR eliptical stylus for £24.99 after all (Amazon listing) and I'll have to fork out about £40 for one via the US.
So, should I still try to get an Eliptical 'stanton' Stylus from LP Gear in the US, or am I better off switching to Ortofon? I also note that Juno are selling an Ortofon OM PRO S with matching PRO S needle for £38.75: here . Would switching to this be better than going for the LP Gear 'stanton' stylus at around the same price?
As for the new drive belt. Well it's not as saggy as the old one but a problem remains. I have to move the pitch slider up to about +2 in order to get the platter to spin at the right speed. It's spinning slow. The good news is that because it's a DJ style deck with pitch slider and dots on the platter, I can use my eyes to see when the 'red' dots are steady, and thus the speed is correct. I presume that the 'pots' or holes next to the slider (seen in the YT video below) are there to deal with this exact issue. I don't understand why it happens though. Motor slowing down? Can anyone reccomend any particular screwdrivers for these, or offer any other advice? I have found a couple of YT videos on this subject since starting this post actually. See below.
As for the preamp, once I've got a (hopefully) satisfctory stylus sorted, is it worth my while improving on my BTECH? I'm thinking of a Pro Ject Phono Box MM (£69 on Amazon, £30-ish used on Ebay) or its cheaper sibling The Phono Box E (£45 new on Amazon and reportedly almost identical to the Phono Box MM).
And finally I've recently noticed mobile phone "dit dit dit" interference occasionally coming out of the speakers when I'm switched to the record player. I'm not sure if it's my own phone or the phone of a neighbour on the other side of the wall. Is it the stylus that's picking up the interferance? Any easy/cheap solutions?
Soundlab turntable with its adjustng pots/holes visible here circa 30 secs.
Two videos I've just found on correcting the speed. The second one mentions spectacle screwdrivers around the 5 min mark, so I guess that's the answer.
The longer version:
