Hey folks... I wanted a way to make it super easy to switch between 12AX7s and 6N2Ps without having to rewire the socket, so I whipped up this little helper board that sits in between the 6.3Vac heater winding and the sockets. It uses one of those little slide switches that are used to select 120V-240V input voltages for appliances and the like. The board measures roughly 1.25" by 2.25", so it's easy to tuck away into the corner of your project.
You can get all of the design files, including Gerbers all ready to send off to your favorite PCB fabrication house, here:
https://github.com/thorpej/Electronics/tree/master/Tube_Audio/Helper_Circuits/9A_9AJ_Heater_Helper
Enjoy!
Enjoy!
