Depends on you just use it for load only, or you ever going to run distortion analyzing (THD testing). I had experience buying those high wattage non inductive resistors that is non linear and cause THD measurement to be wrong.One of the items on my DIY list was to make a dummy load for testing and troubleshooting amplifiers and receivers.
I was expecting to have to cobble together a bunch of 50 watt resistors =- having done this several years ago.
The reason for expecting to use 50 watt resistors was the cost - high wattage resistors are expensive and I'm on a budget.
But! eBay to the rescue. I love that marketplace.
I located a guy selling a batch (15) power resistors - mostly 50 ohm 100 watt which I was quite prepared to lash together to give me 12 ohms for testing with.
Well, this guy also had what is in the picture below - a pair of 8 ohm 300 watt Milwaukee ballast resistors. 300 watts!!! Exactly 8 ohms!!!
My Dummy Load will be ready shortly. The big (12 inches long!) double resistor at the top of the picture is the 8 ohm 300 watt unit. One of the 50 ohm 100 watt resistors is showing in the box.
Paul
Also, do not trust some of those metal panel mount 8ohm 100W or so resistor from ebay. I ordered a few, they are small, like less than 3" long only and very narrow. I complained to the seller and he kept saying it's right. The size is so much smaller than a real Dale 100W resistor. From my experience in the field, it's no more than 25W size. So if you buy from those place, don't count on their claim.
I read before people use those water heater elements you can get in kitchen house hold store. I have no experience, those might be cheaper. Take your meter to the store and measure the resistance!!! I'll let people that try this to give you more info.
