Well that's a common arrangement, sometimes known as 240 meaning that they're in a 240 degree arc. The other common arrangements are 180 and a full circle, so if they provide a picture you'll know right away if it's the right one. Is there a reason you need a right angle?Yes it is a 5 pin connector. Darn there are several different types. Here is a photo of the connector. I may just leave it as is or cut it and make an adapter to RCA jacks mounted on the chassis. Then at least I can use higher quality cables from there.
John
Well, yes, 4 intervals or arcs of 60 degrees each, but the total spread from the 1st pin to the 5th is 240 degrees, and that is how supply houses describe them.The 5 pin tonearm plugs have 60 degree spacing
