making an adapter
I have an eico 667 and I want to test older 4, 6 and 7 pin tubes. How do people make their adapters for this type of thing? My first thought was to use a 9 pin sub miniature but I quickly realized the glass would be a problem. After carefully breaking apart a 12AT7 to conserve the base and soldering up the pins it broke apart in my hands. Doh!
4,6,7 pin sockets with wires to lugs should do the trik. use a small plastic tube filled with rtv, or epoxy to rigid things up abit. cheep and dirty.
I just got a 666.
The best way to make one is get the correct size brass rods and solder them into a 9 pin socket, cut the pins twice as long as needed so the will stick out enough when seated in the 9 pin socket .
