Making audio sound BETTER??
My YAMAHA decks have a "PLAY TRIM" function that is really effective when you play cassettes with Dolby ON. You just turn the "PLAY TRIM" until the music regains it's sparkle.
Enabling noise reduction on a tape that was not recorded with the same type of noise reduction will almost always result in degraded sound.
Most NR systems rely on an encode/decode set of parameters. When properly set up and executed the desired effect of noise reduction is achieved without a loss of fidelity.
