Making tube socket holes.
HiFiCanada
Caregiver
Once I get my General Radio 1203-B power supply for the WA-P2 Heathkit preamps, I want to install two tube sockets on the side of the power supply.
I want to use the 1 in tube sockets, the same tube sockets that take the KT88 tubes and slip them in the new holes that I just made.
I won a Greenlee 7307 conduit slug splitter knock out punch kit set - 1/2" thru 2"
and got it coming, I think that should just be ideal for making nice clean holes , should it?
I don't see any special punch set for making tube socket holes, so I figure this should work.
Is this what is used to make tube socket holes?
Thanks in advance
Bob
those are pipe sized punches... look into greenlee 730 series (radio chassis) punches. they are sized to nominal dimensions such as required for most sockets
I live in London and have a set of appropriate punches. Let me know if you need to borrow any.
Last time I made holes for tube sockets I bought one of those stepped drill
bits and it really does make nice clean holes using it with a drill press.:yes:
Unibits work, but I like punches better when they are available in suitable size and of good quality. It seems to take a lot more file work to de-burr a unibit drilled hole than a punched hole. Unfortunately I do not own a set of punches, so I just do a lot of file dressing.
I guess if you can get to both sides to use the bit to deburr it its not so bad. Last hole I punched in something, I couldn't fit the bit in there from the bottom side and it came out a bit ugly. Should have been a suitable quality bit, its an actual Irwin Unibit that I was using. It left some ugliness inside that took some work with the half round to clean up.
Pretty hard to get a cleaner hole then with of quality punch set, but the step drills do a nice job and are quicker for sure.
