arcorob
Addicted Member
Been obsessing over tube amps, thought I let it go. Yeah right..
Found an offer I could not refuse. Right watts per channel, beautiful design...sigh. Stats and pictures below...
6L6 Baldwin amp conversions from organ use to hi-fi that I've done.
All of the organ components (motor drives, etc.) have been carefully removed and the amp has been gone through to insure proper trouble free operation and reliability. Baldwin's engineering is impeccable and because this amp was designed to reproduce music from an organ keyboard, the amp is very low distortion and doesn't add any coloration to the source material. It does have the warm, clear sound that is characteristic of 6L6 amps.
The unit produces 27 watts per channel RMS in stereo via huge under chassis mounted output transformers. All transformers are super sized and are of the cloth lead type. The power supply is very large and uses 2ea 5U4's as well as a large filter choke. and multi-stage cap. This amp is silent when idling,but is capable of very high volume levels so the amp has very good dynamic range. All tubes have been carefully matched and are included in this sale.
Following is a list of features built into this exceptional amp:
1. Three prong plug with chassis earth ground.
2. Fuses for BOTH AC and DC power.
3. LED power on indicator (Red)
4. 2 sets of stereo inputs, switch selectable.
5 High quality on-off switch
6. Beautiful hardwood cabinet finished in hand rubbed lacquered mahogany
7. All tubes are included and hand matched for performance.
8 high quality speaker connections
9 Complete user instructions with photos for tube locations.
10 Level controls for each of the 2 channels of the unit
