Are you "Shure" they're being truthful? Pun intended lol.It just says "Fiction-free precision stainless steel pivot joints".
@Jos Collin
Actually Jos, it's painfully obvious just with a quick look, that the Shure SFG-2 isn't even close to being able to produce an accurate weight. The number scale is a 1 1/2 cent, little piece of silver-coated tape. And the cheap markings printed on it are nowhere near properly scaled, regarding the thickness and positioning of the printed lines. And imagine how much the positioning of the piece of tape itself varies from unit to unit.
The 'cheap' (well, let's say inexpensive) digital scales are accurate, every time, to a tenth of a gram, without any guesswork involved; as proven by myself, and 90% of the posters on this thread. And the height, or angle from the pivot, doesn't change the weight at all. It's ridiculous that the height of the scale, varying by a quarter inch would even be mentioned. Sheesh ... that's what I mean by over-preciseness.
Do yourself a favor, and try not to let yourself be misdirected by the enthusiast, tinkerer types, unless, of course, you also enjoy tinkering with turntables etc.. This friendly advice covers pretty much any hobby.
And hopefully I haven't offended anyone that likes to fuss around with their gear, just cuz I don't like to. It is a hobby, after all.
But facts and opinions aside, have fun with whatever you use.
Cheers.
Dave
On the beam in big letters mine says stainless steel. If yours is new dont worry it will be stainless
Chris
I think a digital scale made to measure your body weight is very different to a "jewelers" scale that we use for measuring tracking weight. The human scale is probably cheaply made with not a fine tolerance. The digital scales I've tested for turntable use have all been accurate and reliable with calibration weights on repeated testing.Got the delivery yesterday. It looks good, very simple mechanism. I have checked with a magnet, it is pure stainless steel. I will measure the tracking force on my TT today.
Regarding the digital weighing machines, I had tried measuring my own weight many times in my office. May be it improves the measurement with another gauge, but this one always shows random numbers. I could weigh myself 10 times and produce 10 different numbers. I think most of the digital weighing machines work that way. We need to "believe" what it shows is correct. There is no way to explain why it shows that particular number and it is correct.
Rather a manual gauge works based on our expectations. We need to set the expected weight first and it shows the result based on the counter weight we set on the gauge.
Exactly
The OP is attempting to justify his purchase of the less accurate, more expensive analog scale over the easier to use, more accurate, less expensive digital scale.
Scales to measure body weight sold for home use whether digital or analog are ridiculously inaccurate, the digital scales just show the lack of tolerance more clearly, or accurately eh lol?
No Sir. That's not true. I'm not trying to justify my purshase at all. Your reasoning that a Digital gauge shows accurate values doesn't sound logical to me. Mostly it shows a magic value to me. It may or may not be correct.
This post is verging on an attack.. Hmm..Wow, now you are definitely attempting to convince even yourself lol. The digital scale comes with a weight to test for accuracy as has been stated several times by several members in this thread. No mystery about the accuracy of its readings eh?
The Shure scale comes with no such device to check it's accuracy eh? Now the accuracy of which scales readings are in question eh?
The digital have a test weight which is needed as the digital drift wildly and need that weight yo get them close every time they are used
Done here as you seem to enjoy having your head in the sand.
10 dollar digital are not accurate at all.Exactly
"At all" is relative, I suppose. Compared to a $1000 scale, probably true. Compared to the SFG-2, or many counterweights, laughable.10 dollar digital are not accurate at all.
Chris
I honestly would not weigh brass cases to get them similar with a 10 dollar digital scale they drift like crazy they can easily by 0.5g out measurement to measurement. Any beam scale will beat that accuracy 10 fold."At all" is relative, I suppose. Compared to a $1000 scale, probably true. Compared to the SFG-2, or many counterweights, laughable.![]()
Here are 3 sets of ten readings with mine, with the tare weight, a 5/16" nut, and a foam earplug:I honestly would not weigh brass cases to get them similar with a 10 dollar digital scale they drift like crazy they can easily by 0.5g out measurement to measurement. Any beam scale will beat that accuracy 10 fold.
Chris
tare weight:
4.994
4.995
4.993
4.993
4.994
4.993
4.995
4.996
4.993
4.995
max - min = 0.003
5/16” nut:
3.291
3.291
3.288
3.288
3.291
3.290
3.289
3.292
3.290
3.289
max - min = 0.004
foam earplug:
0.485
0.483
0.488
0.485
0.482
0.484
0.484
0.486
0.483
0.485
max - min = 0.006
I suppose someone who is both accurate and precise in remembering those definitions, and in remembering their statistics, may come along and quantify both, assuming the tare weight really is 5.000g.
Until then, it looks like my scale is about 100 times as precise as yours.
Either you bought a very, very, very crappy digital scale, or you are spreading FUD on the internet. Which is it?
Either that, or $4 more buys a LOT of improvement...I believe it's the latter eh?
