Hello dear marantz-enthusiasts. Alas, my dear 4400 beast stopped playing its wondrous tunes yesterday...
I have had repairs done on it before and some months ago I fixed a distorted sound on one channel after finding that one of the output trannies was loose !
But yesterday I found that all its channels were dead even phones jack. Connecting my kenwood kr 10000 through jumpers to marantz I found that the marantz preamp still worked.
After inspection I found that the top 1s2724 rectifiers before filter caps was dead.
From reading an interesting suggestion in a post by Echowars;
http://audiokarma.org/forums/index.php?threads/marantz-4400-quad-repair.42452/
, I took out the two diodes and replaced them with a 35A 4 terminal bridge... and .... it worked!!
All channels are back online and the receiver once again sound great....
However, a new issue has emerged and I'm at a loss.
The scope that previously worked, now has an issue I don't understand. Instead of being focused as a dot, it makes a somewhat circular curve on the screen when music is off. In stereo mode it still moves somewhat correctly but in varimatrix it clearly does not.
Strangely also when disconnecting the big wire plug to scope assembly board, this scope curve is still there even when scope button is turned off.
My 2sk30 trannies that I've replaced a few years ago seem okey. Could there be current leaking into the scope from somewhere...causing a curve instead of dot?
If anyone can give me any pointers as to what might be the problem or have any ideas about this issue I would be very thankful.
I guess the issue could have arisen as a result of swapping the diodes for a bridge... otherwise maybe something took a blow when the rectifier stopped working but I didn't see any smoke etc.
Well, if anyone comes up with anything It would be much appreciated. I really want to keep this beast with a functional scope
Mm and one more thing, are the ceramic small caps that were wired before the filter cap rectifiers still mandatory to have when using a 35A bridge? I have tried both ways and it seems to work either way...
