Nac458
Member
Hello all,
So there I was.
I had just completed an entire re-cap for the little 1030 amp. I was excited to hit the switch and resolve the "bad capacitor problem" on the power amp board. But upon doing so, only the left channel was able to come through and I was left disheartened and discouraged.
Upon further inspection I replaced a few fried resistors that slipped my eye but alas, still nothing from the right channel. So I took some time to watch this video:
(and I learned quite a few things).
As I'm a hobbyist, I don't have much test equipment, nor do I have experience with such. So I decided to replace the transistors on the pre-amp board and most on the power amp board in hope of bringing the right channel back and giving it a clean bill of health. Note that I now receive no sound from either channel, and the resistor R738 is smoking and burning up after the transistor swap, while the other R737 sits content.
Unfortunately, I did not do my homework before diving in, and I'm left stuck with the following NTE (yeah, I know
) replacements on the boards (currently):
POWER AMP BOARD
H709-H712: (2SC959, 2SA606) with NTE128 - I know these NTE parts are all NPN transistors and they should be NPN/PNP pairs, respectively. I will have appropriate PNP transistors for H711 & H712.
H705-H706: (2SC371) with NTE 289A
H707-H708: (2SA562) with NTE 290A
PRE AMP BOARD
H501-H506: (2SC458) with NTE 85
Is this a transistor problem, or does the problem lie somewhere in the bias?
Any help would be most appreciated.
Thanks!
So there I was.
) replacements on the boards (currently):POWER AMP BOARD
PRE AMP BOARD
Thanks!
