Richs_Trains
Well-Known Member
Hey all, Got a 1040, again, bought it for the wood case, but figured I'd check it out. Being new to all this, I am still learning. When I connect it to a DBT, it passes, until I engage the speaker switch, then I get a bright bulb. I never left it on long enough to see if there is sound as I was worried about the bulb going bright. I was told previously that if it passes at idle, it is ok to power it on the main. I just don't want to do any additional damage if something is wrong. I did re-cap the power supply and almost all of the power amp (short 1 cap). I am able to set the dc and bias to spec. Is it ok to go to main power and try speakers?
Thanks Rich
Thanks Rich
