resoundpdx
I am working on a major rebuild/recap of a 1060 and have run into an area I don't recall seeing addressed in the the many past threads/postings on the 1060: grounding. The unit I am rebuilding has clearly been worked on by someone before, so it is not always clear what is original and what is not. And while I do have the repair manual and schematic, I have not found these to be 100% accurate/dependable.
What I am finding is the following: there are short straps connecting the circuit ground directly to chassis on the power supply board, the tone board, and the power amp board (but not the phono board). There is also a short strap connecting the negative side of the big 4700uF filter cap to chassis. And the shields of all of the input connectors are also tied directly to chassis. Since there are also wired ground connections between the various boards (and from the filter cap to the power amp board), isn't this a recipe for ground loops?
If I replace the main power cord with a three wire one (and tie the green wire to chassis inside the amp) will I make things worse (create more problems)?
Related question: all of the connections (including those from the filter cap) to the power amp board have been extended by 9-12 inches, presumably to make it easier to remove/access that board for troubleshooting. I am not too concerned about the outputs, as they will be driving long speaker wire runs eventually in any case. But this seems questionable for the power and ground. (Why upgrade to an ultra low ESR/ESL filter cap and then connect via a long thin wire?) At a minimum it seems like these power/ground wires should be beefed up in gauge if the runs are extended.
Am I worrying needlessly here?
