MBuras
Restoration is an Addiction
Almost since the beginning of my time on this forum I've heard derogatory comments about the 1060B amplifier. Build quality is terrible, sound is terrible, nothing like the original 1060, etc. So of course I had to find out for myself.
This one came to me in great cosmetic shape and relatively clean compared to most pieces its age.
The problem as noted by the previous owner is that when hooked up to speakers and turned on there was just a loud hum. I confirmed the loud hum regardless of volume being all the way off. And here's where my learning experience comes into play.
I automatically assumed it was a bad filter capacitor. I pulled them and they both measured high on ESR, one much higher than the other. This fed into my reasoning and so I ordered parts cuz I was going to rebuild anyway.
After getting my parts order and rebuilding the power section I was completely mystified when the hum continued. Then followed days of crazy ideas like checking ground connections, checking the rectifier diodes, checking the power switch snubber, etc. No joy.
And then the most brilliant idea ever....check the manual. Duh! And sure enough there is a section on troubleshooting hum.
Point number 3 addresses the issue. I had already replaced the filter capacitors (C808, C809) and the other two power supply capacitors mentioned. That left Q801. Hmmm...hadn't checked that before. Compared voltages to the schematic and something definitely off. Pulled Q801 and put it on my little Ebay tester. Confirmed bad. Decided to check the other 4 power section transistors while I was in there. Also found Q802, Q812 and Q813 were bad. Yikes!
Fired up after power section transistor replacement (after DBT), heard a brief buzz and then silence. Alright, I don't like the buzz but silence after is good, right? Nope. Although all is quiet it's also not playing any music I'm feeding it through Aux.
I noticed on the schematic that Q801 also connects to the preamp board so start checking voltages on QE05 and QE06. One side is fine, the other not so much. Pull them both and test bad. Pulled all preamp transistors while in there and found QE03 and QE04 were bad as well. Replaced all, restested with DBT and sure enough there was music. Yay!!
Goes to show that assuming something is a problem isn't the right way to go. Checking the basics is always a good move. And learning how to at least follow connections/voltages on a schematic (even if you don't completely understand the purpose of the circuit design) is super helpful. I'll put this experience in my toolbox for reference in the future. More learning is good!
Finished pics to follow...
