Thanks for those numbers. They are a start. I'm gonna try and come up with something measuring what I have., if I do, I will post it. The couplers I bought many years ago do operate correctly, so I think it's just a matter of getting the right cells.I’m aware of no published spec for either the optocouplers assys or the CdS cells. My notes indicate a dark resistance of >20MΩ, ~ 60 Ω in bright light and ~ 200 Ω in the light of a new NE2 close coupled to the cell and driven with DC (only 1 of the 2 wire electrodes illuminated). I don’t think the absolute value of the resistance is too critical but if you have a properly operating optocoupler, by all means measure it in its two states.
I actually have some replacements that some guy made 20 or 30 years ago. Just looking for some replacements for those. I should probably take some apart and make some. Thanks.
Steve O mentions "long life neon lamps". Is there a special designation for a long life NE2 lamp? I purchased these USA made NOS Sylvania lamps off of Ebay.
Consider too that at some point while the 10B was “current”, Marantz issued a service bulletin regarding the opto isolators and how to test them in-circuit for proper operation. Obviously, Marantz knew they had a potential problem with opto-isolator life.
Steve O, I have a Service Bulletin that is titled "Marantz Model 10B Check-Out." It is number 69-11/10B-1 and is dated 9-19-69. Is that the one that you are referencing?
Shawnnnn, do you have a link to that post from the Klipsch forum?Mine still work so hopefully I never need to try this but I read this on the Klipsch forum. No idea if it's actually this simple or even works:
Marantz 10B Photocells: This is actually a minor problem: They leak usually, because they are not properly closed anymore. They let light in then (sorry for my bad English). All that needs to be done is to carefully open them and laquer them newly. That's all, and then they work fine again. No need to get new ones."
