Marantz 1120 pilot lamp replacement
saabracer23
AK Subscriber
I’m about done with the rebuild on my 1120 and I believe the last thing to do is to replace the pilot lamp. It looks like the appropriate replacement is a 28v 40mA bulb.
I want to make sure I was actually getting voltage to the lamp in case the lamp was fine. Well I’m measuring 45Vdc at the lamp terminals. That seems high to me. I’m assuming that would destroy any new 28v lamps I’d put in.
Looking at the schematic I’d im reading it correctly it looks like it’s getting power from the +44.0v rail using a 1 watt 390 ohm resistor between the lamp and the 44 volts.
Thoughts?
Dan
The 390 Ohm resistor will drop about 16V at 40ma, what you are seeing is an open circuit with no current draw from the lamp.
Darn, just checked and this bulb is bare wires and I have a box of bayonet and a box of 382s, both 28V bulbs.
Since I just got an 1120, I was hoping I had something I could use in its rebuild, received in non-working condition, no outputs installed, stuff disconnected. Oh well, one day. But I know what bulb I need.
I am about to replace pilot light on my 1120 and saw a YouTube where the guy suggested to replace that 390ohm (R423) resistor on PS board with a ‘dropping resistor’. What the heck is that? I am having issues w unit so just covering all bases.
