MarantzRefrb
That may be part of your problem, it might be limiting the current too much for proper operation. If you don't see a sustained bright light after power on, you can pull the DBT out of the way.
I would hook both the 250's back up, and let it have full current. But use every precaution, such as a power/surge strip with a master off switch in between the wall and amp.
