Marantz 1200B Repair
CaseyWKC
Hi all, I acquired a 1200B a while back and the parts finally came in today to repair it after it's diagnosis.
Initially the only thing that lit up was the front light, no shorts, in the DBT.
After a recap relay clicked and I got sound and all was well through the right channel. I went through the left amp board and found that Q505, Q507, Q508, and Q521were bad, along with three of the outputs (I confirmed this by swapping all of the damaged parts with the working transistors from the working channel).
So now left channel is good and I know what needs to be ordered for the right channel.
I sourced replacements from Mouser.
2N5680 to replace Q507 and Q508.
MPS6519 for Q521.
MPA4250 for Q505.
MJ21193G for SJ2520
MJ21194G for SJ2519
Threw everything in after double and triple checking both pinout and my placement in the board. Soldered her all up and relay clicked a bit longer than I would like after firing it up.
Q507 gets incredibly hot and I'm getting 44 or so volts to right channel speaker output.
I broke everything down and reinstalled the outputs without mounting them on the heatsink as sometimes I've had weird shorts from overtightening and turned it on again attached to the DBT to test. Relay clicked on faster and there was no heat coming from Q507, offset at speaker terminals were below 40 mV.
Figured okay it was a short I tightened it too much or something, reinstalled everything. Boom tons of heat again and 44v coming from speaker terminal.
I have disassembled it all again and now I cannot get it to power on without Q507 shorting / overheating and that 44v going to the term outputs.
I have retested transistors and confirmed transistor placement on the board again as well.
Any insight would be appreciated!
Thanks!
Today I took some measurements with the outputs removed from the good and bad channel to compare the transistor that was heating up Q507.
In the good channel I checked Q505
C- 1.5v
E- 1.335v
B- 1.435v
and Q507
C- .477v
E- 2.03v
B- 1.838v
Now the bad (right) channel
Q507
C- 1.8v
E- 2v
B- 1.928v
and Q505
C- -.7v
E- 1.8v
B- 1.8v
Sooo another update - I realize I didn't order the complementary pair of driver transistors for Q507 and Q508, I only ordered two of the 2N5680 PNPs from Mouser.
So that's a problem right there, I took the one that shouldn't be out after going over the schematic again. So now I only have 2N5680 in Q507 where it should be.
So I guess I just need to order the correct transistor from Mouser for Q508 which is a 2N5682.
They must be matched right, as in I can't use the old working NPN transistor to test and see if this triggers the relay and solves the heating issue?
Taking a break now :).
Transistors 2N5680 and 2N5682 came in today, after installation the heat issue is gone but I can't get relay to energize.
Perhaps these are not the correct replacements or I need to check other transistors?
I am quite new to this haha.
I swapped the pre driver transistors from Q507 and Q508 to the non working channel to confirm I ordered the wrong trans and relay kicked on and it fired right up.
The hFE for them both is around 126.
What did I do wrong sourcing transistor 2N5680 for Q507 and 2N5682 for Q508?
What do I need instead?
Take a look at this post. It's for a 16B, but the same two transistors you are looking to replace.
https://audiokarma.org/forums/index.php?threads/model-16b-transistor-subs.694431/post-12567295
Q507 (PNP) SS9306 2N5416 $16.80​
Q508 (NPN) SS9305 2N3440 $13.19​
Both are available on Digikey (although not cheap).
I saw those recommended for substitutes as well but am confused as to why the 2N5680 and 2N5682 are not compatible, is the hFE too high in 2N5682, it's around 217 on both I ordered while the 2N5680 is around ~130. And the hFE in Q507 and Q508, they both need to be the same, or as close as possible?
Those are quite expensive, are these not the same ?
and
Thank you!
Update :
I put the 2N5680 and 2N5682 in the working left channel and it fired up and engaged relay fine, right channel still having issues, guess this means the substitutes should work but I have another issue up the chain, going to check the resistors on the relay now.
I don't know why the difference in price??? It sounds like you have another issue on the R channel.
and
Thank you!
Update :
All transistors have to be matched per the service bulletin(s) for the 240/250/250M given that the 1200 uses the same circuit. I believe the 3440/5416 is specc'd over the ones you used due to the HFe being guaranteed to be within the range of the service bulletin/easier to match, more robust specs for voltage, and a slower transition speed more in line with what the originals probably were. There's no harm in using your subs if they are stable but you have to be careful.
I saw that but I guess I overthink things, so perfect. What I ordered is an okay substitute just gotta watch the temps once I get things up and running and make the service adjustments.
You are correct, I now cannot get the relay to energize in either channel.
I got to the relay board last night and found R701, R712, and R713 off spec so I replaced those. And I replaced C701, C705, and C702.
Still no relay. I did substitute two non polars w/ the same uF rating @ 50 volts for C705 and C701 (originally 22uF @ 50v polar cap), is that an issue?
Thanks.
You did put the 220uF in the correct location for C702, correct?
I'm not sure why you replaced the electrolytics for C701 & C705 with non-polarized caps, they are not in the audio path. Did you put in non-polarized electrolytics or film caps?
Double check that you did put the resistors in the correct locations. Also, check for cold solder joints or bridges.
Those 6 parts are the only components that you changed?
Correct, that is the only thing changed since last time I heard the relay energize. And yes they are in the correct location. I can post pictures this evening when I return home.
I was under the impression there weren’t issues replacing a polar capacitor with an NPE. Is this not the case?
What is the DC voltage on pin 5 and pin 6 of the relay board? Also, what is the DC voltage one the collector of Q703 and Q702?
NPE = Non-polarized electrolytic? NPE's are essentially two polarized caps connected in series in opposite directions. They are not needed in this situation. Those caps are probably used as a time delay for triggering the relay and I'm not sure that the voltage discharge curve is the same for NPE vs polarized.
I know they weren't necessary it is just what I had available and I thought they could be used instead, I have replaced the two capacitors with the normal 22uf polar capacitors. No relay.
Pin 5 of relay when powered on measures about 5.78v and drops to 4.65v.
Pin 6 measured 1.6v and then began to slowly increase until I powered it off after it hit 1.7v at ten or so seconds.
Q507 collector measures 1.817v
Q508 collector measures 1.865v
Thank you!
I had asked about the collector voltages of 703 and Q702?
Q507(c) should be 0.7V
Q508(c) should be -0.7V
As for relay pins 5 & 6, I don't have the pin-out numbering for the relay. Did you mean Relay Board pad 5 & 6?
Here is a description of how the time constant works.
OK, if I understand your measurements correctly, you measured 5.78V on pad 5 of the Relay Board. According to the description of how the circuit works, if you have a DC voltage over +4.5V, Q701 will turn on and will de-energize the relay. Your measurement exceeded the +4.5V value so the relay will de-energize. Either you have a problem with the DC offset out of the Main Amp channel, or another circuit problem. See schematic below.
I think that you can adjust this offset with R502. (See schematic below)
Looks like it's the R channel that has the high DC offset.
Connect your DC voltmeter to pin 5 of the Relay Board.
Mark the current position of the wiper of R502, then turn it slightly one way while monitoring the voltage.
If it goes higher, then you need to turn it the other way. See if you can get it close to 0V.
If it doesn't change or you can't get it to 0V then there might be another issue. Return it back to the original position.
My apologies I definitely shouldn't have replied that late as tired as I was.
I did mean relay board pad 5 and 6 yes, those measurements are what I got.
Q507 and 508 measurements were wrong because I didn't have the positive lead on the couplers.
The measurements for the originally requested Q703 is around 1.27v.
Q702 I wasn't sure which was collector and my soldering iron **** out so I had to get a new one this morning. Last night I got 1.5 - 1.6 and 14.5v on each leg.
So here's where it gets stranger. I'm really sorry not trying to make any of this confusing. I was trying to get the relay to energize with the pos lead disconnected from the R or L amplifier board, as that's how I got the relay to energize the very first time I got the unit after recapping the power supply.
Today after checking Q507 and 508 again I just hooked up both leads to the couplers and the relay energized within seconds.
Couldn't get L or R to energize on their own like I had before, maybe that's a good thing?
Now with both leads on the couplers relay energizes for both channels.
I'm taking some measurements and going to see if it cooperates with the outputs.
Thank you!
Questions:
1) Why do you suspect there is something wrong with Q507 & Q508? Those transistors are on the Power Amp board. (See schematic below)
2) I'm not sure what you mean by "couplers". What on the schematic are you referring to? So, in the case of Q703 & Q704 - which lead are you referring to (EBC)?
  • In most cases, the voltage measurements are referenced to ground (or chassis ground).
  • The black lead of your DMM should be connected to the chassis and red lead to the component you are trying to measure.
  • Please, when you provide a voltage measurement for a transistor - just don't state the value, but also which lead you are measuring (Emitter, Base, or Collector). It is somewhat meaningless otherwise.
For measuring the collector of Q702 and Q703,m measure the red dots:
Questions:
1. Q507 and Q508 were dead on one of the amp boards originally when I got the unit, I thought the substitutes I ordered were an issue/incompatible.
2. The leads on the big filter capacitors that are split to each amplifier board. I should have just called them big filter caps and not couplers.
And sorry about the random values for Q702, I took it off to locate collector.
Q702 C is now getting 19v and dropping to around .7 when relay kicks on.
Also yes looking at the same schematic going by the 1200B addendum and am taking measurements with my DMM chassis to ground.
That's good.
So now that the relay "clicks", the voltages at both pads 5 & 6 are probably close to 0V and not 5.78V like before. (See board diagram on post #17)
What do you measure now on 5 & 6 when the relay clicks?
That's good.
5 is .064v
6 is -.8v.
Measurements taken with both leads from both amp boards after relay energizes.
Just got it all put back together and going over service adjustments. The right channel seems to be operating like it should and will energize relay by itself now, but it is making my DBT dim and that wasn't happening before.
Left channel is distorted and goes back and forth between energizing and not. Nasty looking oscillations.
Pulling apart again.
Edit : The transformer in the amplifier makes an audible hum when the bad channel does not energize the relay. The hum is not present with just the working right amp board lead attached.
:oops:
