Marantz 125 no output
quadmatrix82
AK Subscriber
Hi tuner experts I’m working on a Marantz 125 tuner which has no output I suspect a power supply issue there is no output for AM and FM bands and the tuner meters does not move.
I got zero voltage at test point j404
h407 I test approx 14v on emitter and base points
H403 I test 41v emitter, 44.3v collector and 41.9v base
the caps have been replaced
the transistors have been replaced
H407 original d315
H401-2 ksc1845
H403 - ksc2383
zener diode was checked and replaced but seemed to make no difference h404
what else should I check to narrow this down? Thanks!
H407 original d315
H401-2 ksc1845
H403 - ksc2383
If you have 14V at H407's emitter and 0V at J404 there's a break on the PCB between those two points:
