Marantz 1250 Restore
rhodus
AK Subscriber
Impulse buy off the e site. Not a lot of info on these. I think it might be a TOTL in its day. Its had a bit of work over the years. Butcher work. The fuse holder is missing. Amp boards and power supply screws are loose and some missing as if the last repair tech just gave up. The outputs have all been replaced with NTE devices. Speaker jacks are both broken. Cosmetically its a solid 8/10. All knobs are present and the faceplate is acceptable. Any knowledge/opinions appreciated.
It is a solid unit. If the cosmetics are good it is worth the investment fixing. I have one that is almost the reverse - broken switches, scratched faceplate. It came for cheap with a blown transformer which I fixed - it was just the thermal fuse. I wasn't able to find a suitable donor to get one put together.
Which outputs would you recommend to replace the NTE units? Also, one side of the dual filter cap measures 12,000uf, the other side 13,000uf. What would you replace it with?
The usual suspects - MJ21195/6 should work well. A for the dual cap I've been called names for it but I gut it and stuff it with four 6800uF/80v of the smallest size I can find.
I read in another 1250 thread that the original outputs, 2sc1116a/2sa747a were 10mhz while the onsemi units are 4mhz. Is there an issue with that difference?
Although that is true, the difference is not that much and it could be in the unit's favor. MJs are also more linear than the Sanken. If the boards are repaired and restored correctly I wouldn't expect any negative outcome.
Correct. The Sanken parts were/are way better than the junk Mot/ONSEMI parts. And, coming out of the Mexico fab, they were even worse.
Stick to the original Japanese parts if you can find them.
I am not going to get into a debate, please use your discretion and research abilities about the outputs. I must say I am more worried about the drivers on your board - they are NTE and I am not sure how well they will perform.
. Mexico does not have any onsemi fabs, why do you not look before you spread incorrect information. Onsemi packages the metal cans in Mexico and have done so for many years now.
Onsemi is the only reputable manufacturer that offers a usable solution to a current metal can device for new designs and for servicing. Folks should be thankful that they continue to do so since the Japanese gave up years ago, leaving the world with out supply.
Sanken does not even make that package today and haven't for many years now.
Offering advise to AK members to source parts that in many cases are fakes is not doing any justice to our members. Saying "if you can find them" not offering a reputable place to buy them is of no help to our members wanting to learn and do the right thing.
I have no problems designing new power amps using said onsemi devices that far exceed the specifications of this Marantz 1250.
I have plenty original 2sb600/2sd555 from Pioneer SX1250/Spec2 projects....would they be suitable replacements?
Why not see if it works the way it is first before trying to change parts?
Because there is no way to know WTF NTE put their number on. If you ever looked up NTE cross reference, it shows bunches of things crossing to the same NTE part. Like one size fits all BS. No, NTE is a terrible choice for parts.
Mainly because it seems somebody already attempted repairs and gave up. The missing fuseholder is the most obvious sign. Both amp boards show signs of major repairs. Both speaker jacks are broken, the dual filter cap is cooked, and I've never heard anything good about NTE. My plan is to address these issues first and then dim bulb test. I have a new fuseholder, Mouser has some caps that might fit, and a new speaker jack is on the way.
I have some NTE driver transistors in my sx-950, been running fine for >30 years now. Am I going to change them? = No sense to. Don't fix what's not broken philosophy.
When I used them I did not know as much as I know now, would not recommend them now but that does not mean they would not work as I have demonstrated.
NTE is a dead entity, end of story, move on.
You can test semis for opens/shorts with DMM in diode test mode as a sanity test.
Good approach in above post #14, good luck
I much agree. I could have that amp up and running in a couple of hours.
I'll be getting on it in a few weeks. Its Hot season here and I am swamped with AC work. I have received new fuseholder and speaker terminals. I also have a pair of 15000uf caps that will physically fit, and I will be putting the SX1250 outputs in. THEN I will dim bulb it to see what happens. I plan on recapping it anyway, so none of the cost or effort will be wasted. Plus, a Man has to know his limitations, and act accordingly.
It's just a good idea, IMO and IME, not to go changing out a bunch of components in an unknown unit, just because of the possibility of inadvertently installing a fault where one didn't previously exist. Then you end up really spinning your wheels.
I got back on it today and was able to get the replacement speaker jacks installed, replacement fuseholder installed, straightened the damaged back panel at the ground terminal, and installed new main filter caps using the Mod Board from Peace, Love, and Music. Tomorrow I hope to get the amps back in and fire it up on DBT.
