Hello there,
In the past, I had issues with the left channel of my Marantz 140. I serviced my Marantz 140 as :
- Changed the big cap for two 15 000uF 63V Mundorf
- Changed all the transistors except the pre driver and drivers on left channel
- Changed two diodes on both channels
- BIAS and DC adjusted on both channels
- Both channels has been recapped last 3 years
- New relay since last 3 years
I moved to a new appartment and now the buzz/rumble/hum is back. My VU metter goes left and right on the left channel when I have the issue. There is no distorsion in the sound, only buzz/rumble/hum.
I tried several things as :
Revers RCA cable of the pre out, issue did not changed side
Volume knobs have no impact of the issue
I have the issue on all sources
The mode knob on the pre amp have no impact
Tried a MP3 player connected directly to the amp, still have the issue.
Yesterday, I realised when I'm playing with the power cable of my turntable, the left channel goes almost silence and playing well. The turntable is grounded to the pre-amp. The issue is intermittent but arrives more often since I moved.
My question, do I'm getting face to a ground loop issue finally? What I need to check? Which additional test I can do?
Many thanks in advance.
Guy
Guy
