Hello there,
I created a few post regarding my Marantz 140 under "Solid State" here in AK website and a user told me to submit my issue here. Here my situation :
I acquire a Marantz combo 140/3600 from eBay in the last 3 years, which is a very good combo and I really like it. But, for random reasons, the left channel give me some headache. Sometimes, the left channel is doing a buzzing/hum sound and is rumbling (i can see the woofer going back and forth and the VU meter going crazy on the Marantz 140 - left channel). I can temporary resolve the issue by touching/playing my turntable outlet, power off/power on the Marantz 3600 or last time I turned on my tapedeck Marantz 5020 and the buzzing/hum was disappear. It happened one or two time when I power on the combo for the first time of the day, I can hear the buzz/hum immediatly when the relay of the Marantz 140 kicks.
Here what I did on the Marantz 140 :
Replaced the filter/main cap for 2 x 15 000uF 63V Mundorf
New relay
LEFT CHANNEL :
All caps replaced
Replaced all TO-92 transistors including differential TO-92 thermal coupled and shrink tubed.
Replaced the two diodes
Replaced the BIAS transistor (had issues with BIAS adjustement in the past)
BIAS and DC adjusted
Checked for cracked solder joints (I may double check this one more time)
Re-solder/fixed the ground wire from the left heatsink.
RIGHT CHANNEL :
All caps replaced
Troubleshooting
Tried to swap the RCA cables from the Marantz 140. The buzz/hum still on left side.
Volume knob (pre-amp and the amp) have no impact
Push buttons (loudness, low/mid/high freq on pre-amp) have no impact
Seems like the only thing still untouched on the left channel is the pre-drivers, drivers and output transistors.
What other troubleshootings I can do to be able to fix my issue? I plugged another power amp for testing and all seems running fine for now. (Marantz 3600 with Yamaha MX-630)
Thanks in advance!
Guy
New relay
LEFT CHANNEL :
All caps replaced
RIGHT CHANNEL :
All caps replaced
Troubleshooting
Thanks in advance!
Guy
