WhammaJamma
Hollow State Afficionado
Hi Tony,
I hope this gets to you in reasonable time. I have been busy here and now at midnight I have a few minutes to check postings. On your amp the components in question appear to be in the feedback circuit which feeds back some of the output audio back to the input and the desired feedback phase is 180 degrees to suppress oscillations. Putting your finger near a transistor or on it and you introduce stray capacitance to those sensitive parts which accounts for the change in what you are hearing at the speaker. Looking at this circuit and the component values unless I missed something feeding audio from another amp into the output of this one does not seem possible to affect the components you are looking at. You can replace those transistors as a sort of shotgun fix. If that fails then you will need an oscilloscope to trace the signals in search of the offending oscillation. Even though you are hearing a low frequency oscillation at the speaker bear in mind the scope may show an oscillation at 100Khz or so.
To summarize my thoughts, the problem could be before the transistors in question. It is hard to say what the effect would be in that circuit if one of the transistors were intermittent but typically they just quit and would not exhibit the low frequency oscillation you describe. An oscilloscope sure would be handy to visualize the signal path! Do you have a scope or can you acquire one?
-Duane
Oh yes, you have that curve tracer to test the transistors. If the curves look good over a range of temperature and compare they are good.
-Duane
