Marantz 150 Scope queston
Here are the voltages at the scope pins, taken with a focused bright dot:
PCB 900 specified voltages with bright dot
Pin # Pin # Voltage Read with Fluke 87 III
1 J930 ===== -970 -965 6.22ACv
2 J932 ===== -960 -959
3 J931 ===== -970 -948 Bright varies -873 to -956
4 J934 ===== -840 -828 Focus varies -447 to -956
5 J929 ===== +120 +118
6 J928 ===== +120 +113
7 J927 ===== ?
11 J927 ===== +120 +119
12 J926 ===== +120 +117
13 J925 ===== +120 +116
14 J933 ===== -970 -963 6.22ACv
About the beam intensifier, The Handbook of Instructions says on the bottom of page 5 under section 3: "adjust BRIGHT so that the dot is barely visible. Automatic beam intensifier circuitry will brighten the display when trace deflecting signals are applied to the horizontal or vertical amplifiers."
Can one be tested on a CRT tester and if so what settings should one use unless it is in the tester manual
My 150 scope is not working and I think that it is a problem with the filament
voltage as I only measure 4.5VAC, I would think that it should be 6.3VAC.
Does anyone know what the filament voltage is for the Toshiba 85DB1/7J3 CRT is?
I believe your correct the filament voltage should be 6.3 VAC. I think this supply comes from a separate secondary winding from your power transformer. I have had good success using my beam builder in getting the CRT to display a good visible image. As in the post above yes the focus and anode voltages come from a power supply. I don't know if your CRT has an accelerator grid and a second anode, but both deal with some fairly high voltages so be careful probing them with a DVM may be around 2KV. I'll see if my beam builder has any information about your Toshiba 85DB1/7J3 CRT.
Ok thank you
If you keep the heater at the same DC potential (-500V to -900V) as the cathode, you can eliminate arcing between the two. There is, of course, 6VAC across the heater to make it emit electrons.
Tom
Hi Tom,
I'm trying to resuscitate a 120B tuner with a dim scope. With the Brightness control at maximum, all the functions display correctly except the CRT is extremely dim when in "Audio" (squiggly line) mode. I measure 1006VDC at heater terminals 1 and 14 at the tube and 6.6VAC at their respective connection pins on the P900 scope display board (J916 and J924). So it would seem the CRT is getting plenty of juice as all the other sockets on the tube connector have voltages at or slightly higher than specified in the service manual.
In your estimations, would this indicate the need for a new tube? And if so, might you have an idea how to safely remove and reinstall the deflection coil (L005) that seems to be glued to the current tube? Thanks in advance for any suggestions and advice! Pat
Please excuse my ignorance, but what exactly is a "beam builder?"
