Nac458
Member
Hey all,
I've just recently completed a complete re-cap and restoration of a Marantz 170DC.
I received the unit in non-working condition. The entire right channel amplifier was disassembled and the output transistors had been removed as they were burned/shorted.
I went in and replaced components that appeared to be out of spec: all capacitors (including the main filter cap), any burned resistors/diodes in the right channel, the smaller output transistors on the 'mini' heatsinks on either amplifier board, plus all the fuse lamps in the VU meters up front.
Fast forward to being substantially complete.
I had to toggle with the soldering points behind the amplifier boards as the circuitry has seen better days and is a tad corroded. I fixed all cold solder joints and even did a bit of point to point soldering for the weaker areas.
Giving it a first listen and it sounds incredible! Really like nothing I've heard before.
About 10 - 15 minutes into my listening session, I noticed the left side of the amp (left channel) was significantly warmer than the right. I switched it off and proceeded to take measurements for DC offset. I used the R719 trimming resistor to adjust the offset, yet when I would get it right where I wanted +/- 0.5 mV the reading would gradually veer off (yes, the gain was turned all the way down). I ended up with somewhere around -500mV! I did some poking around today - testing continuity between some shoddy areas, and tried again. No difference, except the trimming resistor doesn't even seem to get close to the 0mV I was able to achieve before. It was reading somewhere in the 2V range!
Could it be a bad trimming resistor? Or a smaller transistor?
Is that a good place to start?
