bktheking
Gitter Done!
Thanks guys. It went back on the bench this morning just to set the audio crap, dc and bias. Thank god I checked it, had over 1V on the DC reading. Dug back into to amp driver board, 2 more bad transistors found, got it down to 0V on the speaker terminals and set the bias to .08V. I also forgot to mention- this thing has 2 relays for speaker protection, not just one. So if you have a channel cut out like mine did on the left side, it's the relay contacts that are dirty. As well, anyone with an 18 and the black power switch should pull the bottom panel and check it out, you may see this as I did, the switch was hanging on by a thread of plastic, when I removed it the terminal fell off.
