I would have grabbed that thing if it was still there on the second visit. Not risking someone else grabbing it. I made a 6 hour trek to pick up my Model 19 including 2 ferry rides.
I just found out from a local audio pro that with a self powered sub, I can run a "Y connection " off the Marantz 18's "tape record output", (it is constant), so any other component will run through that tape record output.
I know. I came home with a $35 DEAL OFF Craigslist:L Sony receiver(150w + 2),SONY 200 CP, AND SOME KLH AV5001B'S. THE WIFE LOVED THE SOUND SO MUCH it's replacing the living room and I get the scraps....:tears:your new Marantz 18 deserves a far better match than a a subwoofer paired with a couple Bose speakers...
I am going to use the KLH AV5001B's once it gets hereYou don't want to use the "tape" output, it has a fixed output and you sub's volume will not go up and down to stay matched with the Bose when you raise or lower the 18's volume control.
In your case, best to look for a "powered" sub that has "speaker level" inputs and get the signal to the sub that way via the 18's speaker posts. Understand, you are not driving the sub with with the 18...the sub has it's own amp powering it, it is just getting the signal from the speaker wire and not the rca jacks.
I suppose you could hook up a passive sub to the 18's "remote" speaker terminals and the Bose to the "main" and then select "both" on the front panel. Me...I wouldn't. Good luck, the 18 is special.
