KutzlerTrans
Jennie & I with Buddy and Barney.
Hey tuner guys, and girls.
First time in the Tuner section for me.
I am about to install a rohn 23/25?G tower for my tv antenna..
I also have a pile of antenna parts saved for a future fm antenna.
As a result of having to eventually work/add or swap antennas, i am installing a pivot.
The tower is around 35' tall. I plan to add at least 10ft, but as of now only have a cut in half old CM antenna, so wind resistance is nothing. I would like to put up a parabolic 7" CMaster if i could find one.
As far as making an FM antenna, i would stick to something around 12' length do to the dual frame CM quantum 1160 antenna i am going to base it on.
That is material for a whole nuther thread
These questions sound like i am talking more tv than FM but i just want to make the connection.
Here is one question.
In theory since tv is UHF, and based on line of sight, i should be able to pick up a signal out to about 185 miles as long as the transmtter is around 35ft up.
Questions,
1)
So, am guessing FM is more like VHF but also confined to the curve of the earth, which for Uhf every ten ft of height, would increase coverage to 25 miles?
Or, is there an issue with ground interference that explains why my tv only gets out to 80 miles.
It appears to me that the only way for the
{D = 1.33 x (2x height of my antenna) + 1.33 x ( 2x height of transmitter) } formula would work, is if there was a fudge factor of 40 ft.
Not knowing transmiter tower height does not help , as i have no clue.
Question 2)
So, is FM different than Uhf when it comes to this calculation?
I bought a marantz 20b that i am going to restore electronically and send to my friend Rbuckner for an allignment. He doesn,'t know this yet so i'm crossing my fingers until he gets back on ak and cks his messages.
I have heard of a guy called Punkerx that is a master at massaging every ounce out of these 20b's
Mr PunkerX, if your out there and Randy declines or is too busy, could you help me?
I restore Marantz receivers but know my limits as far as Fm goes.
I'm sure i'll get to know you guys when i tear into this restoration.
Question 3)
What is the optimum height for an Fm antenna before cable length takes its toal on the signal?
Question 4)
When i do eventualy add the fm antenna , does placing it below the tv antenna comprimise the signal as i think it would?
Question 5)
How many ft should they be apart?
Question #5)
Lightning!
I have the welder for permanantly welding the braided copper cable to both the tower and ground rod.
How do i best protect the tuner from getting hit?
Thanks for your advice, John
Questions,
1)
Question 2)
Question 3)
Question 4)
Question 5)
Question #5)
Lightning!
