Hi,
I just finished recapping a 2220b and was shifting to a 2225. I am looking at the service manuals and nearly every board is identical.
I am comparing the caps and transistors for the main driver, eq, tone amp, etc and they are exactly the same
(the 2225 adds a mic amp to the toner board, but otherwise the same).
Same power supply board, supply caps and AC-coupling caps.
The 2225 delivers 5 more watts/channel using the same main amp boards as the 2220b by getting a bit more supply voltage (+/- 31V vs +/- 30V for the 2220b)
Same power supplies, so the transformer secondary must be outputting slightly higher AC for the 2225.
Anyway, these 2 models should sound very (very) similar based on the boards they share.
Or am I missing something...?
Tom
Tom
