Richs_Trains
Well-Known Member
Hey Guys, Decided to put the 1150 on hold and found a 2220b that looked good on the outside, but..... the inside has had a rough time with moisture and rust. It arrived in ok shape and only suffered a broken speaker terminal in shipping. I replaced the speaker terminal and powered it up on a dbt. Seemed ok, but no sound from the FM, switched to AM and got radio signal. Connected an external tuner and the unit actually plays fine. Since the 2220b has the boards exposed on the underside, I decided to just start recapping with what I had available. I recapped the power supply and the two FM boards (not the actual tuner). The boards in the center where the rust was concentrated had a total of six caps that the legs just fell off, so I am guessing they were not doing anything. After replacing all the caps that I had, I now have FM, but cannot get stereo and the sound is about 50% of the volume of the external tuner, also the signal strength meter does seem to move, but not really function. I know that this is probably beyond my abilities, remember I pretty much have a meter and a soldering iron, but I am hoping one of you miracle workers might have a suggestion that turns out to be an easy fix. As always THANKS Rich
