I have a 2225 that the owner reported a loud intermittent noise issue through his speakers. The unit appeared to be all original inside. It took a few hours for the noise to start. It was independent of volume setting and limited just to the RCH. I replaced all electrolytics on P700 MAIN AMP. BOARD. The differential pairs on P700, H701/703 and H702/704, were 2SA722. The SM I have listed them as being 2SA763. While neither of those are known to be problematic I went ahead and replaced them with matched pairs of KSA992. While I was at it I also recapped PE01 PRE TONE AMP. BOARD, cleaned all the controls, set the bias and offset. All seemed good...until it wasn't. After several hours the static noise came back, and this time much louder than what I had initially experienced and more like what the owner had described. Again, only in the right channel. I swapped P700 signal input pins J701 and J702 and the noise was now in the LCH. So this suggests to me that the issue is upstream from the power amp. The transistors listed in the SM for then PE01 preamp PCB are 2SC1328 and 2SA763, neither of which I believe are problematic. I haven't confirmed what's actually on that PCB yet. Thoughts anyone? There is a board marked PH01 that seems to be in the signal path between the pre and power amp. No active devices on it, but there are a couple of tantalum capacitors. I've pulled enough bad tantalums in the past that I generally replace them, however in this case there would be a bit of work involved to get access to that board.
